I searched a couple pages and saw that I am not the only one with this problem. Some people's screens partially work (tilt/open), and some don't move at all.
My screen either works perfectly or it won't move at all. Kinda sounds like loose wiring to me, or maybe something occasionally gets stuck in the gears? Other than the confirmation beep, I don't hear the motor or anything at all. I really don't know what to make of this. Like many others, I get the "beep" to drop the screen, but nothing happens. When I try to Tilt +, I get a beep, then it exits the tilt screen menu. I have had this thing since July 2006. It's the version that allowed me to flick my lights for the bypass (before I upgraded to garret's Z3 drive). The screen functions have worked flawlessly until a month ago.
In my searches, some people mentioned a ribbon cable that you can't really see unless it's open. Even then, you don't want to touch it. Somebody mentioned removing a sticker to access the gears--is this the white/black pioneer sticker? Someone mentioned the screen coming off track--mine slides all the way up/down with no problem...when it works, so that probably isn't it. Did I miss anything or read something wrong?
My screen had been motionless all day, then when I tried it 30 minutes ago, it opened like it was 2006 all over again. I'm fairly confused, and definitely frustrated with this thing. If anybody can point out anything that I may have missed, please chime in. Thanks!
