I just got a Pioneer F500BT for my car. The unit is designed to interface with a custom Pioneer amp that bypasses the car stereo output to route voice directions and cell phone calls to the factory stereo speakers. The unit has an "amp control" wire that tells the pioneer amp when to mute the stereo and pass audio control over to the GPS.
My factory stereo in my car (Pontiac G8 GT) has a 'telephone mute' wire and an input (+/- mono) for cell phone audio input. These wires are currently connected to onstar audio.
I am almost certain that the mute wire on the radio will mute the audio when it senses a ground signal. I have tested the 'amp control' wire coming from the GPS, and it is normally open (no positive voltage or connection to ground). When the GPS gives a voice command, the wire then closes to ground, with about a 300-400ohm resistance, and I can also measure about 0.18 volts on the line. So in theory if I can get the voltage right, it will function like a mute wire, muting the radio only when there is audio output from the GPS
First I would like to know if this wire, as it is, will work to mute my factory radio?
Also, if not, I would like to know if the 300-400 ohm to ground it provides would be enough to trip a negative triggered relay, to then open up a direct ground connection for the radio mute?
I've attached a crude diagram of how I plan to tap into the factory wiring on the radio...
Thanks.
