Unit randomly changes source (F90BT)
By xero8p · Mar 03, 2009in Problems/Troubleshooting💬 7 posts👁️ 1,004 views
Posted Mar 03, 2009 · 19:02 UTC#1
Just got mine installed yesterday and the unit has a couple of times now kinda went nuts and would just start cycling/changing through the sources randomly. The first time it happened (on the freeway) after a few minutes of it I was able to take control again. This morning it happened right after starting the vehicle and continued until we shut the car off (about 10-15 minutes). But it was fine when we came back out and went home.
It is a F90 BT, Sirius Tuner, HD Tuner, PAC Steering Wheel Interface and it has the hardware bypass.
Any ideas, hints, suggestions?
Posted Mar 03, 2009 · 20:14 UTC#2
Quite possibly PAC getting stuck... Can you try disconnecting it and seeing if it keeps happening?
Posted Mar 03, 2009 · 20:44 UTC#3
will try that, well or at least get the shop to do it hehe
Posted Mar 08, 2009 · 18:44 UTC#4
OK yeah I can confirm the it was the PAC Steerwing wheel interface. Had the shop unplug it real quick and it has worked fine for days now.
Posted Mar 20, 2009 · 14:34 UTC#5
what was the solution to this problem? Im having the same exact problem.
Posted Mar 20, 2009 · 15:30 UTC#6
i would try programming something different to that button and see if the new button goes crazy, if so i would skip the SOURCE button in the PAC programming so at least every other button works
Posted Aug 23, 2009 · 06:17 UTC#7
My F90BT is changing sources automatically too, and I also have a PAC installed.
Anyone find any fix? I still want to retain my steering wheel controllers so the PAC is a must. I don't want to have to remove the entire thing.
