So ya, the system seems to work fine.
I did a reset in the screen where it lists 3D calibration.
Now if I go back to that screen it just says Sensor is calibrating or something like that.
Also, in the Map selection area if I select the screen that shows the speedo etc I get a message over the speedo that says This function not available.
The tracking works fine, I have a good GPS signal and have at least 300 miles of driving on it now.
No I don't have the speed sense wire plugged in and I have never had it plugged in. The speedo has always worked, at least when it had the Z1 drive.
I read through the manual looking for some setting, I've played in about every screen and I cant seen to find a solution.
So I'm here asking for advice.
What am I missing?
