Problem with hardware bypass.
By oddjobbb · Mar 05, 2009in Hacks/Mods💬 5 posts👁️ 1,421 views
Posted Mar 05, 2009 · 01:21 UTC#1
I did the hardware bypass yesterday on my 350Z. DVD plays fine when in motion as does the the nav system. however i noticed that my brake line stays on and my check engine light came on. So i undid the parking brake ground and the idiot lights went out but now the nav and DVD wont work when the parking brake is released. Any ideas on where i went wrong??
RJ
Posted Mar 05, 2009 · 03:02 UTC#2
when you ground the parking brake wire you only ground it from the radio
dont connect it to the parking brake and then ground it
Posted Mar 05, 2009 · 03:04 UTC#3
gotcha thanks for the help. :D
Posted Mar 05, 2009 · 08:39 UTC#4
Just put the parking brake wire to any ground, it works fine.
Posted Mar 06, 2009 · 09:58 UTC#5
I think you connected and grounded YOUR car's parking break up instead of the unit.
try connecting the unit's ground instead and the moved mute wire. leave the wires in your car alone, but first you gotta reconnect them.
