Right now the yellow wire is showing constant power.
The Red wire from unit has a piece of paper that has ACC on it.
The wire on the harness say 12 v ignition.
This is from the wiring harness instructions.
'In the Ford/Lincoln/Mercury vehicles listed on back there are no 12 volt accessory wires in the factory radio harness making the installer run an accessory wire to the fuse box or underneath the steering column
when installing an aftermarket radio. The XSVI-5520-NAV is designed to provide a 12 volt 10 amp switched accessory output along with the rest of the wires needed to install an aftermarket radio. The
R.A.P. (Retained Accessory Power) function is retained by the XSVI-5520-NAV.
The XSVI-5520-NAV also provides essential wires required for aftermarket radios that have navigation.
Provided is VSS (Vehicle Speed Sense), Reverse, and Parking Brake. This cuts down the installation time since the installer does not have to look for these wires in the vehicle.
So is the reason there is no power coming out because of this.
INITIALIZE THE XSVI INTERFACE BEFORE TURNING ON RADIO: With all connections made and harnesses connected to the vehicle, turn ignition key to the ON position for thirty seconds, then turn
key off.
