Finally took pic's!
By Fen911 · Mar 05, 2009in General💬 18 posts👁️ 4,424 views
Posted Mar 05, 2009 · 02:40 UTC#1
Have mine in my Nissan Versa since Feb 7 and so far so good. I havent had any problems with the unit so far. The bypass works perfect. Just wanted to thank everyone for there input.
Posted Mar 05, 2009 · 04:46 UTC#2
Awesome! That looks nice. I have a 2009 Nissan Versan and I'm awaiting my F700BT in the mail. Was wondering how it would look. That's a nice fit.
Did you install it yourself or get it done by a pro?
Posted Mar 05, 2009 · 13:45 UTC#3
I did it myself. The only hard part was running the backup camera wire, but other than that it took me about 4 hours.
Posted Mar 05, 2009 · 15:17 UTC#4
Did you use any tool to remove the top dashboard panel? After reading how to remove the old deck online, I gave that a little tug and it seems quiet firm. I wouldn't want to break it. :shock:
Posted Mar 06, 2009 · 02:10 UTC#5
just pull it towards you, don't be afraid it wont break. I take it off all the time.
Posted Mar 06, 2009 · 02:51 UTC#6
is that your stock scheme?? looks nice
Posted Mar 07, 2009 · 00:43 UTC#7
Yes I kept it stock, no mods YET.
Posted Mar 07, 2009 · 00:47 UTC#8
Whoa Versa owners!
Looks good! The install was very simple.. where did you put your GPS antenna?? If you're creative, its probably where mine is, too. I have a f90bt in mine.
If you're looking for a Versa forum, this one is great..
http://www.nissanversa.org/
ScottDoom..
I pulled mine off by hand. Just lift it up firmly and then pull it towards you. Should snap right out.
In fact I just pulled it straight up firmly and cautiously and it eventually snapped out.. good thing nothing broke. I wish I would have knew to pull it forward the first time.
Posted Mar 07, 2009 · 01:09 UTC#9
I put my antenna right behind the radio antenna on the roof of the car. I think it looks good and not very noticeable and of course I get great reception. When I get a chance I'll post a pic.
Posted Mar 07, 2009 · 01:13 UTC#10
Awesome. I was really concerned about where I was going to put the antenna and I really wasn't looking forward to running wires everywhere. I started brainstorming and decided to put it in the dash on top of the little cubby. Works great!
Posted Mar 07, 2009 · 16:31 UTC#11
So you put the antenna right on top of that little "cabinet" thing above the deck slot?
I must be pretty dumb because I didn't realize how many diferent things I would need to find a place for. I'm talking about the GPS antenna, microphone, and USB cable of course.
Since you guys have a Versa like me, where did you end up putting these?
I think I will put my antenna inside the dash since that seems to work fine, although I might just have it up on the dash in the far front of the shelf near the windshield.
I want the USB cable to go through to the inside of that "cabinet" or the glove compartment but I have no idea how easy that will be. Will I need to drill a hole?
For the mic, I have no idea. Any suggestions would be great.
Posted Mar 07, 2009 · 18:30 UTC#12
http://forums.nicoclub.com/zerothread?id=388538
I have a few more pictures in there. I put my mic on top of my steering column and it works great there. It was totally easy to run the wire, just have a friend drop the mic down inside the dash and go to the floor on the driver's side and pull it thru up to the steering column. You might need small hands, but you'll see what I mean when you get to it.
As for your first question, yes, it is mounted right on top of the little cabinet. Great reception for me. There are a lot of options, but I just wanted it hidden. 8)
Here is the tutorial I used to drill into the cabinet. I ran my USB and Ipod cable thru it. It was pretty easy. Skip the steps with the glove compartment.
http://www.nicoclub.com/articles.php?id=267206
Posted Mar 12, 2009 · 18:40 UTC#13
I installed it last night/this morning. I think it took me around 3 hours. It was my first stereo install ever, and I was pretty impressed at the job I did. Very clean.
I drilled a hole into my cubby for the USB cable, but I couldn't find a grommet to fill the hole. So, to keep he USB cable from slipping back down and into the dash, I used electrical tape on the bottom side. Haha. Kind of ghetto, but it can't be seen and does the job.
I put the GPS antenna on top of the cubby inside the dash, as you mentioned. I haven't tested it too much yet, so I hope it works...
Also, I opted to not even install the mic. I didn't want to bother with finding a location, and I don't ever plan on using the Bluetooth to make calls and I don't own an iPod.
I loaded an 8GB SDHC card up with 1,000+ songs last night, and I've been using that. Works great, and the navigation of the files is exactly how I wanted it.
Posted Mar 13, 2009 · 00:26 UTC#14
This is my antenna. I don't think its that noticeable.
Posted Mar 13, 2009 · 22:06 UTC#15
That looks really clean. Nice job. :)
BTW, your pictures aren't showing for me. I saw your pics in the GPS antenna thread and they show there.
Posted Mar 13, 2009 · 23:30 UTC#16
Thanx. I didn't think it would bring to much attention, and I get good reception even in manhattan with all those buildings.
Posted Apr 23, 2009 · 00:33 UTC#17
Looks great! did you use an installation kit or trim plate? i have an f90 in transit and i want it to look like this when i install.
Posted Apr 25, 2009 · 01:04 UTC#18
Yes I got it on ebay,it came with the antenna adapter and wire harness also. if i remember i got it for 34.99 + 5 S&H
