Transfering contacts from bb storm to pioneer bluetooth
By diggs702 · Mar 05, 2009in Problems/Troubleshooting💬 12 posts👁️ 2,483 views
Posted Mar 05, 2009 · 21:08 UTC#1
Okay I figured out how to transfer contacts to my avic d3 bluetooth from my bb storm. First thing you have to do is pair the two devices. Then go to your head unit and go to the function screen for BT and go to transfer contacts. Next on your storm go to manage connection and select Bluetooth options. Under paired devices highlight the Pioneer BT unit and hit the menu key and go to "device properties". Once you are there scrool down to where you see "services". Hit the menu key and go to "Refresh Service List". It will take a moment when its done it should say "Object Push" under services now. Now you can go to the menu key and go to "transfer contacts". Let me know if you have any questions I hope this helps.
Posted Mar 05, 2009 · 21:42 UTC#2
Hey thanks for the info. Do you have any idea if there is some sorta fix for being able to adjust the volume from the storm when using the BT on the Z2/Z3?
With my old phone I was able to adjust the volume right from the phone, but with the storm it seems fixed....
Posted Mar 05, 2009 · 21:51 UTC#3
Im not sure. I'm not that familiar with the Z2 and Z3.
Posted Mar 12, 2009 · 20:06 UTC#4
I have a BB storm and I cant get mine to automatically pair with my D3 when I turn my truck on like with my last verizon phone. Ive got all the settings right I think-- what did you have to do???
Posted Mar 12, 2009 · 20:39 UTC#5
I still cant get mine to pair automatically, and when I tried to transfer the contacts like you said my "transfer contacts" button on the D3 screen isnt highlighted so I cant press it... I just got this phone and Im already getting pissed at it.
Off topic- does yours freeze up for like 5 minutes when you try to take a video sometimes??? Also does it take longer than usual sometimes for the screen to flip when you turn it from portrait view to landscape?
Posted Mar 13, 2009 · 00:15 UTC#6
Did you register the phone on the unit and make sure your setting on the phone is set to "always discoverable". That should fix it and yes the phone does lag a bit when turning it to the side view.
Posted Mar 13, 2009 · 00:16 UTC#7
Posted Mar 13, 2009 · 01:53 UTC#8
yeah its set to YES on discoverable. I dont know why it wont sync automatically
Posted Mar 14, 2009 · 17:52 UTC#9
Once you connect your phone you have to register it on the D3 for it to auto connect.
Posted Mar 18, 2009 · 21:01 UTC#10
oh Ill give that a try then, thanks
Posted Jun 10, 2010 · 18:49 UTC#11
Used this with my Storm2 (9520) and D3, worked without problems, thanks for posting this guide :)
Posted Jul 19, 2010 · 18:16 UTC#12
When I click the menu (blackberry) button while my AVIC-Z120BT is highlighted, I see "Transfer Contacts". I chose that and it sent them. I have a Storm 9530.
