F700BT Booting Straight Into Backup View
By jamesxmizo · Mar 05, 2009in Problems/Troubleshooting💬 5 posts👁️ 778 views
Posted Mar 05, 2009 · 21:18 UTC#1
Hey guys, I just installed my unit yesterday and when I start it up, it boots right into the rearview mode and won't switch out for at least 5 minutes or so. How can I change this? I would like it to boot into the Top Menu, if possible.
Posted Mar 05, 2009 · 23:24 UTC#2
After it boots up, head into the settings and set the backup camera view option, there's an issue where occasionally it comes up with no entry in that option that cause the all blank screens.
Posted Mar 05, 2009 · 23:32 UTC#3
Its more than likely that you might have the polarity set wrong. There are 2 options for Battery and Ground Polarity. Try setting it to the other option, that should fix your problems.
Posted Mar 05, 2009 · 23:45 UTC#4
Well I'm not saying my camera doesn't work.. I'm just saying I don't think it should boot right into that screen, you know? Like I get a Splash screen and then straight into Rearview, I have to press MAP for anything else to show up.. pretty annoying
Posted Mar 06, 2009 · 05:20 UTC#5
Did you wire the reverse wire properly? It sounds like the unit thinks you're in reverse.
