sub out crossover point too low?
By Eddywill · Mar 05, 2009in General💬 4 posts👁️ 709 views
Posted Mar 05, 2009 · 22:33 UTC#1
Ok I will try to be as clear as possible and I just want to know if anyone else has encountered this. I am using the sub out on my F90bt to drive some powerful aftermarket subs. I listen to a lot of music but mostly classic rock - on my previous setup (avic N2) I do not think the sub out had a factory crossover point built in. Here is why I pose the question. I feel like I need a little higher crossover point. - I thump now but mainly the kick drum on the previous setup I think I ran closer to 200hz or maybe a tad higher as I like the bass guitar to come thru... I am going to split the rear output into my crossover and try that . Has anyone else had a similar thought or issue?
I can lift the rear wheels off the ground with Yeah by Usher but the bass guitar is gone from Rush and Van Halen etc thanks Eddy
Posted Mar 06, 2009 · 02:08 UTC#2
cant u run it off the rear rca instead of sub rca. or are running an amp for door speakers
Posted Mar 06, 2009 · 02:21 UTC#3
I am using the four rca outs I am going the split the rear outs and try that!
Posted Mar 06, 2009 · 15:41 UTC#4
cool that will work
