Pioneer avic n2 parking break
By demetrius316 · Mar 06, 2009in General💬 7 posts👁️ 1,587 views
Posted Mar 06, 2009 · 03:43 UTC#1
Hi i have a problem with my n2 it tell me the in navgation initialzation is currenty in progress or there maybe a improper connection of the parking break lead.Now the radio i had was a 7500dvd that i took out of my truck to installed the n2.So i used the same plug from the 7500dvd.The n2 already have the solder bypass done to it.To me it look like the unit is not seening the parking break wire.Let me know what u guys think about this isssue that im having and thanks.It load the map disk and restarted the unit so the disk are fine.
Posted Mar 06, 2009 · 05:12 UTC#2
Do you have the parking brake wire grounded?
Posted Mar 07, 2009 · 15:51 UTC#3
yes the parking break is grounded.
Posted Mar 08, 2009 · 19:54 UTC#4
Then the bypass wasn't done right
Posted Mar 09, 2009 · 00:25 UTC#5
Ok i get that redone tmr and let u know
Posted Mar 09, 2009 · 14:00 UTC#6
ok I looked at da bypass that was done and the solder was thick.So I desolder that and now I only see 2 holes in the borad where the solder was at.Can I take the unit apart and get to it from the other side.
Posted Apr 09, 2009 · 05:12 UTC#7
The side you have already seen should have done the trick. The harnesses may not be interchangeable, but I am not 100% sure of this...
