turn on headlights, deck does not dim
By baehan · Mar 06, 2009in Problems/Troubleshooting💬 2 posts👁️ 655 views
Posted Mar 06, 2009 · 05:14 UTC#1
my setup is a 2006 toyota sequoia limited with the avic d3, ipod cable, BT200, backup camera. is there a wiring issue here? did the installer not connect a proper wire? when the headlights turn on, isn't the deck supposed to dim down? i see there is a setting there to adjust the dimmer setting. thank you.
Posted Mar 06, 2009 · 05:15 UTC#2
Does the map turn black when you turn your headlights on? If not, the installer didn't hook up the illumination wire
