can i listen F500BT music on my car speakers without NGD500?
By aramis11 · Mar 06, 2009in General💬 5 posts👁️ 1,592 views
Posted Mar 06, 2009 · 11:25 UTC#1
hi,
Can i connect F500BT to my car radio aux input directly in order to use my car ampli and speakers? (without ND-G500
Posted Mar 06, 2009 · 11:53 UTC#2
hi,
Yes you can but the signal from the F500BT is pretty weak and you'll probably need a ground loop isolator to eliminate hum.
Posted Mar 06, 2009 · 20:35 UTC#3
I currently have mine going through a cassette adapter & it works pretty well. No hum anyway in my New Beetle.
Next week I am getting it custom installed.
Seperate power in (hot all the time)
I am having it mounted on a mount that sits in front & below the dash.
It's so big I could miss a truck in the blindspot otherwise.
New headunit with DVD so I can run it through the AVIC.
Maybe I'll take some before & after pics.
Anyone interested?
Posted Mar 07, 2009 · 01:12 UTC#4
It's always nice to see pictures of the install.
Posted Mar 07, 2009 · 18:02 UTC#5
I will be using the JL Audio CL-RLC to run my amplifiers directly from my F500, as I do not want radio of any sort in my car, nor a traditional "head unit".
The CL-RLC will provide enough output to run any amp cleanly, retails at $60 and is surface or custom mountable.
My only concern is the guidance voice blasting at 120+db!
Luke
