Install z1 on 06 Jeep w/o favtory nav
By brian8pie · Oct 12, 2006in General💬 8 posts👁️ 1,525 views
Posted Oct 12, 2006 · 19:57 UTC#1
How hard/easy will it be to install a Z1 on my 06 Grand Cherokee without factory navigation?? Any help will be greatly appreciated!
Posted Oct 12, 2006 · 20:36 UTC#2
As long as there is a Double DIN opening for the radio, you should be more than fine.
-Litos
Posted Oct 12, 2006 · 21:26 UTC#3
Just make sure you actually have a double din opening. I dont know about the 06 models, but I know that in the past, a lot of Jeeps had 1 3/4" DIN openings, not double din openings.
Go to Crutchfield.com and put your model car in. They are really good about what fits in what car.
Posted Oct 12, 2006 · 21:40 UTC#4
Even if it is a Din and a half could i still make it work?
Posted Oct 12, 2006 · 23:22 UTC#5
You could but it would take modification of the dashboard.
Posted Oct 13, 2006 · 00:26 UTC#6
The only hard part will be making the z1 fit. You will have to modify the dash that surrounds the radio. The stock radio is a little big smaller and has those stupid bumps on the side. It's nothing a bit of work can't fix for you though.
Posted Oct 18, 2006 · 21:54 UTC#7
I installed a AVIC D2 in my jeep G.C. and had to get the dash modifed, you can get a bezel from jeep that will fit it. I had all the work done at a local audio place for $200
Posted Oct 26, 2006 · 04:55 UTC#8
you can get a new bezel from any jeep dealer that will work for the factory nav system and metra makes a kit to fit a double din radio in this opening. your jeep has a din and a half size radio. the z1 is double din and jeeps rec nav unit is bigger than double din. the bezel is less than a 100 and the kit about 30.
