Hi All,
Newbie member - found the forum after searching the web in a panic. I am in a bit of a hole after attempting to install the f900bt into my 2007 VW Passat.
Okay I bit the bullet and bought a new f900 from a UK supplier along with the relevant fitting kit for my car. The fitting kit included Din fascia adaptor and the wiring harness. I looked at a few forums then got stuck in - removing the rubbish VW CD single shot Head Unit no problems. Then I installed the GPS antenna and the Mic speaker into the car. Also no issues with fitting the Din adaptor and the Pioneer cage/ brackets. My issue is with the wiring. I hooked up the harness to the original VW wiring and then the Pioneer harness to this. Brilliant - everything fired up - NAV screen and the GPS position/ Radio worked - Sweet!
Then I realised the following:
* The Head Unit doesnt switch off with the ignition and the cooling fan is on permanently on the rear of the HU.
* As the Green parking wire is not connected - half the menus cannot be accessed via the touch screen.
I have read up on the parking brake wire mod - I believe that i just ground this on the harness to the black wire - Is that right? Do I need a seperate CanBus modulator to control the ignition and the light dimming etc?
Help - has anyone installed the F900 in a 07 Passat - if so how did you wire it? P.S - my car is a Non Nav and has no steering controls from the factory.
Regards, Matt
