Does AVIC-F500BT have enternal gps antenna?
By schumacher · Mar 08, 2009in Pre-Release Archive💬 4 posts👁️ 9,514 views
Posted Mar 08, 2009 · 17:11 UTC#1
Hello,
I'm going to buy F500BT and install it in-dash of my car but i'm afraid it would affect to gps signal.
So, Does AVIC-F500BT have external gps antenna?
If yes where i can buy it?
Thank you very much.
Posted Mar 09, 2009 · 06:37 UTC#2
I called Pioneer about this, they said it did...but an odd connector.
The tech told me where to get it, but I figured I would cobble something together.
My 500 should be here tuesday.
Posted Mar 30, 2009 · 17:24 UTC#3
I know this is an old post, but figured I would answer anyway.
Yes,the F500 has both external antenna and external microphone ports.
Both work wonderfully.
The antenna connector is MMCX. I highly recommend getting a straight connector,the right angle I got is a PITA. The Mic is 2.5mm, same as other Pioneer mics.
Mine now works wonderfully.
Luke
Posted May 16, 2009 · 01:43 UTC#4
EDIT: It is more likely to be the MCX connector which is larger in diameter.
I have a gps antenna with mmcx connector which fits my mio unit and the F500BT is actually larger and won't fit. I think our unit is not MMCX.
Did you get a connector and fit it yourself?
