F500BT reverse wire?
By pjkwong · Mar 08, 2009in Problems/Troubleshooting💬 8 posts👁️ 1,070 views
Posted Mar 08, 2009 · 22:02 UTC#1
Acura RDX is the truck.
Does that wire need to send voltage? It's hooked to send voltage now
It's blowing the fuse in my car when the unit is hooked up.
But if i disconnect the unit and put the car in reverse the fuse doesn't get blown.
The installer said it's the unit that's bad anything else i can check before contacting Pioneer for RMA.
They told me to contact another installer to check reverse wire.
right now i have a quick disconnect for the reverse wire (not connected up for now)
AV source camera view works fine so not really sure
Posted Mar 08, 2009 · 23:46 UTC#2
some where in settings there is a option for the reverse wire
to switch between positive and negative try changeing that first and see what happens
Posted Mar 09, 2009 · 00:15 UTC#3
so you mean use the gnd option instead of battery?
Posted Mar 09, 2009 · 00:51 UTC#4
i dont have a back up cam but that would be the first thing i would try if i was haveing the same prob
if it dont work then i would check the wiring
if that still dont work then wait till someone on here when a back up cam comes on with an answer
Posted Mar 09, 2009 · 03:09 UTC#5
anybody here know before i blow another fuse if i should use the gnd option for the reverse camera?
Posted Mar 09, 2009 · 04:57 UTC#6
Which wire are you tapping into on the vehicle with the reverse wire?
Posted Mar 09, 2009 · 13:12 UTC#7
it's blowing the meter fuse in the car
Posted Mar 26, 2009 · 18:34 UTC#8
I hope its not to late. i just 2 cameras on two Civics. These camera use 3 wires. Positive , negative and a trigger. I connected the hot wire to const battery power, Negative to ground, Trigger to revers light positve lead. Behind the radio you have a trigger wire for the camera. Run that wire to the same revers light positve switch. Go to the radiow menue to back up camera turn it on and select battery. reboot and your done. every time you go into reverse the camera will go on and your radio will switch to revers camera. I did the negative ground but it gave me a lot of problems. I hope this helps.
