Add a pause before speaking directions?
By sykotek · Mar 08, 2009in Hacks/Mods💬 3 posts👁️ 933 views
Posted Mar 08, 2009 · 23:59 UTC#1
Is there any way to get the F500BT to pause about 1 second before speaking voice nav prompts? I have it wired up in my Ponitac G8, but the G8 slowly raises the volume on the input line, so I end up getting the first 1/2 to 1 word of my spoken directions cut off.
I found the voice.zip file and considered adding a 1/2 second pause before every word, but it would sound funny...
Any files that can be modified to add a short pause at the beginning of each voice prompt?
Thanks!!
Steve
Posted Mar 09, 2009 · 08:51 UTC#2
Yes you could do that, but it takes some tweaking of the command list.
Every spoken command is written in the commands list, as (for e.g.)
'% MILES TURN LEFT'
Some command lines have double command lines, for e.g:
'% MILES TURN LEFT TURN LEFT'
when the first isn't available (for whatever reason) it'll go for the back-up command, in this case 'TURN LEFT'
Now, when you would make an *.ogg file (sound file) of 0,5 seconds of nothing, and name that PAUSE, than you could just add PAUSE before every instruction string.
Posted Mar 16, 2009 · 11:50 UTC#3
Well I got this sorted.
It dawned on me that there's that "DING" that sounds every time you get a voice prompt.
I located the file, called !Nav_Dong.wav, and edited it to add 1.0 seconds of silence before the Ding.
Works perfect.
There are a couple phrases that do not trigger the ding, like "You are over the speed limit" and "recalculating", I might modify these to have the 1 second patuse as well, but might not. Last time I tried to modify the .ogg voice files I almost bricked the thing.
