avic z2 bypass need help
By chargeron24's · Mar 09, 2009in Hacks/Mods💬 6 posts👁️ 1,603 views
Posted Mar 09, 2009 · 06:03 UTC#1
Just installed the avic z-2 did the 2 wire bypass moved the mute wire to different position on the plug via directions i received from avic411. plays when im not moving but as soon as i start to drive it stops playing and says watching dvd while driving is prohibited. then when i stop it starts playing again.. i always have volume but the part that shuts down is the visual part of the video. i just want my video to play while i drive without interruption. any and all info will be highly appreciated
Posted Mar 09, 2009 · 14:18 UTC#2
Have you pressed the reset button since you did the bypass? If not, do a reset and see if that fixes your problem.
Posted Mar 09, 2009 · 22:04 UTC#3
i did the reset and still nothing. i get the parking brake wire message
Posted Mar 09, 2009 · 22:09 UTC#4
ALSO I HAVENT DID THE FIRMWARE UPDATE YET TRYING TO FIGURE OUT HOW TO BURN IT..
Posted Mar 10, 2009 · 02:14 UTC#5
OK I TOOK OUT THE DVD DID ANOTHER RESET AND NOW IM WATCHING DVD'S WHILE IN MOTION AND I DID NOT DO ANY FIRMWARE UPDATE. AM I GOING TO GET LOCKED OUT SOONER OR LATER? SHOULD I JUST LEAVE IT ALONE OR SHOULD I STILL FIGURE OUT HOW TO DO THE UPDATE?
ALL INFO IS HIGHLY APPRECIATED.. THANKS!!!!!!!!!!!!!!!!!
Posted Mar 10, 2009 · 02:26 UTC#6
Leave it alone and see if it locks you out in a day or two.
