hello , I need help ,I have avic f90bt, I just wanna know wheres the vss located for equinox 05. thanks
Posted Mar 09, 2009 · 17:19 UTC#1
On the 2007 Equinox the VSS is Dk. Green/ White at the ABS module, Pin #3.
Reverse is Lt. Green at drivers Running Board/ Door Sill.
It may be the same for the 2005.
Good luck. Hope this may help.
thanks, I try that today, do I have to connect the reverse wire too?
According to other posts in the forum, no. But your F90 will be more accurate if you do.
