A couple themes I made
By darkzide · Mar 09, 2009in Hacks/Mods💬 15 posts👁️ 4,028 views
Posted Mar 09, 2009 · 22:36 UTC#1
First off thanks to all the knowledgeable people on this board for all your hard work. Without you guys/girls I would never have been able to successfully make these modifications. I made the start screen images but used other images in the GUI from GUGA and the settings images from marmski. The first set is Bugatti gauges with iPod icons, the second is just some images I came up with...
Enjoy.
Bubble Theme http://rapidshare.com/files/207221052/Image.res.html
Bugatti Theme http://rapidshare.com/files/207221053/Image.res.html
Posted Mar 09, 2009 · 23:38 UTC#2
that is slick dude
Posted Mar 10, 2009 · 00:32 UTC#3
Very creative! I like it.
Posted Mar 10, 2009 · 00:49 UTC#4
ok i admit it i am a noob
and maybe a complete idiot
but where do i put this file
or what do i do to get this on my unit
Posted Mar 10, 2009 · 00:53 UTC#5
Outstanding - I especially like the HTC Phone for Contacts - awesome!!
Posted Mar 10, 2009 · 02:31 UTC#6
1. Get yourself an extra Sd card, download these files -> http://www.avic411.com/forum/download.php?id=4696
2. Extract the zip file and put the 2 folders (MiTACAP and Testmode) onto the SD card.
3. Next put the image.res file on the card. I recommend creating 2 folders like "original image.res" and "modified image.res" Open the modified image.res folder and put the image.res file you downloaded inside.
4. With the ignition off, put in your SD card then power on. You will see files copy. Once that is done, close the window.
5. Now click Start>Programs>Windows Explorer
6. Select the My Flash Disk then (file>open)
7. Next select APL then (file>open)
8. Find the image file, select it then (edit>cut)
9. Next open another Windows Explorer window (see step 5)
10. Select Storage card (file>open) then Original Image.res foler (file>open) then (edit>paste) to back up the original image file.
11. Click up one level then select the modified image.res folder (file>open) select the image file (edit>copy)
12. Now select the other open Windows Explorer window and select (edit>paste)
13. Close all windows, turn off ignition, remove SD card then turn it back on.
I know the is way over explaining, but hopefully it will alleviate most questions
Posted Mar 10, 2009 · 20:33 UTC#7
thanks a lot for this dude nut rapidsh** account says no more downloads than 10. so can't download it. could you upload it somewhere else.
Many thanks.
Posted Mar 11, 2009 · 00:14 UTC#8
thank you very much for all your time and effort
Posted Mar 11, 2009 · 04:29 UTC#9
cant download can someone repost this, thanks
Posted Mar 11, 2009 · 18:29 UTC#10
Thanks guys, glad you like them. I'll see if I can upload them and post a link.
Posted Mar 12, 2009 · 04:06 UTC#11
Wow! they look great !!!
Posted Mar 13, 2009 · 00:35 UTC#12
Could someone re-upload the themes please? Original links don't work.
thanx!
Posted Mar 16, 2009 · 17:33 UTC#14
The bubble theme looks great thanks !!!!
Posted Mar 18, 2009 · 13:22 UTC#15
Please can some one help me to get EU flash images from Avic F900BT ?my Avic don't boot any more after formating his flash ...big thanks...
