BOYO VTL420 Help
By lludacrisboy · Mar 10, 2009in General💬 5 posts👁️ 1,633 views
Posted Mar 10, 2009 · 13:03 UTC#1
Hey i have a BOYO VTL-420 and I'm having trouble figuring out how to wire the unit to my F90BT.
My guess was to hook up the VCC+ wire to the reverse lead, the black gets grounded and the video gets connected to the video on the head unit.
Is that right?....... IF not, How should i do it.
That VCC+ is the one I'm unsure of.
Posted Mar 10, 2009 · 13:34 UTC#2
i have the same rear camera, i think. i hvent hooked it up yet, but i believe it goes to the rear camera signal wire? ithink thats what the wire going into the 90bt is?
Posted Mar 14, 2009 · 01:11 UTC#3
I have the same camera and just installed it last weekend. All I did was connect the black wire to the ground, the red wire to the remote turn on wire from the radio and the composite cable to the rear camera jack. I want to be able to select the rear camera even when I am not in reverse because I installed the camera in the car so I can see my 2 month old in her car seat. Works great. Hope that helps.
Posted Mar 15, 2009 · 18:24 UTC#4
Red to Red, Black to Black, and the other wire connects to the reverse wire from the Avic.
Posted Mar 26, 2009 · 00:27 UTC#5
Yea i want to be able to switch it on also to keep an eye on my Seadoo's. So when you say red wire to remote turn on wire, What do you mean?
Also what did you set the polarity to in settings? Battery or GND?
