Bypass Walkthrough
By JCinderella · Mar 10, 2009in Hacks/Mods💬 17 posts👁️ 4,582 views
Posted Mar 10, 2009 · 21:56 UTC#1
I just got finished the software bypass after spending three days trying to figure it out, and decided that there was probably someone out there with the same problem as me. So I'm gonna set some time aside to write a walkthrough on how I did it.
You have to do the hardwire bypass (grounding the parking break wire instead of hooking it up to your parking break sensor lead) in order for the software bypass to work.
Software Bypass:
Get an SD card and a card reader so you can put files on the card.
Copy and paste these links and download the files to your desktop (http://avic411.com/forum/download.php?id=4696)
Unzip the files all the files and move them all to the SD card. Only unzip the main folder for (F-Series_Firmware_Update2). IMPORTANT: you do not want to click within that file and unzip the (DATA.zip) file that is referred to in many of the hacks.
Open the (F-Series_Firmware_Update2) folder, then (F-Series Firmware Update), then (LPUE080), then (APL2), then (iGo), then (DATA.zip) then (Project_config), then "Pioneer".
This is the file you need to edit for the bypass.
Scroll down the document until you see (parking_break_speed=16.0) and change this to (parking_break_speed=128.0).
Once you change the (Parking_Brake_Speed) to 128.0, you must save the document. Save the document and then close out of it.
Take the SD card out of your card reader and head to your car.
With the car turned off, insert the SD card into the front slot of the AVIC.
Turn on the car.
Give the AVIC a minute or so to fire up and when it does, you should see a screen that says "Copying..."
Once the copying in completed, take a stylus and exit out of that application in the top right corner of the screen.
Click on the "My Device" icon in the top left corner.
Open the "Storage Card" folder and navigate your way to the (DATA.zip) file. [if you forgot...(F-Series_Firmware_Update2) folder, then (F-Series Firmware Update), then (LPUE080), then (APL2), then (iGo), then (DATA.zip)]
Select the (DATA.zip) file, then click edit on the top toolbar and then click "Copy".
Exit out of the current window and reopen "My Device".
Open (Flash Memory) then (LPUE080), then (APL2), then (iGo). Now click the "Edit" button on the top toolbar again, but this time click paste.
A prompt should come up asking you in you want to overwrite the selected file. Click yes and let the copying begin.
After this step close out of everything, take the card out of the slot, turn the car on, let the AVIC start up like normal, and then take it for a test drive to see if your hack worked.
I hope I didn't leave anything out, and if I did, feel free to correct it. Hopefully someone will understand this and be able to do it.
Let me know if it works for you.
Posted Mar 11, 2009 · 13:38 UTC#2
... change the (Parking_Brake_Speed) to 128.0 ...
If you drive 80 MPH or more, you will still get the parking brake incorrectly connected warning. 128 KPH = 79.5 MPH
A better value might be 250 (155 MPH).
Posted Mar 11, 2009 · 17:22 UTC#3
That is not "the" hardwire bypass. The hardwire bypass involves removing the unit from the dash (if already installed) and moving a wire to a different place on the connector, then grounding BOTH that wire and the parking brake wire.
To make the software bypass work you do have to ground the parking brake wire.
Posted Mar 12, 2009 · 05:14 UTC#4
Wait, will this work on the F700BT? It doesn't have a speed cable, so how will the system know how fast the car is going?
I'm needing to do a bypass some way or another because, honestly, I don't even know how to connect the parking brake wire to the parking brake. I'm guessing I'd have to remove all the panels surrounding the parking break and I'm not about to do that.
Posted Mar 12, 2009 · 16:03 UTC#5
I did it on the F700BT.
It's not an actual speed cable, it's the GPS antennae. The GPS knows how fast you're going.
Are you planning on installing this yourself or getting it installed somewhere?
Posted Mar 12, 2009 · 16:04 UTC#6
I followed the software bypass hack from jcinderella's post but when i go to click on the pioneer.ini file i get this error message : THE FILENAME, DIRECTORY NAME OR VOLUME LABEL SYNTAX IS INCORRECT.
WHATS UP WITH THAT?
Posted Mar 12, 2009 · 16:06 UTC#7
I've never seen that before. Make sure you're not trying to open the pioneer.ini file, you're just trying to copy and paste it onto the head unit. I don't know if that's what the issue is but that's the only thing I can think of.
Posted Mar 13, 2009 · 13:44 UTC#8
Thanks. The pioneer.ini file comes up as a blank notepad. should I Type (parking_break_speed=128.0) in the notepad myself and then save it? or am I doing something wrong?
Posted Mar 13, 2009 · 20:22 UTC#9
Great walk through. Is this the same method for all hacks? (Aka going into the pioneer unit and clicking copy with your file in the SD slot?) sounds easy. :D
Posted Mar 14, 2009 · 08:15 UTC#10
sounds great....
however:
is not working for me... what is this second file?
Posted Mar 16, 2009 · 19:40 UTC#11
All of the files can be found here.
viewtopic.php?f=34&t=18977
Scroll down to the first reply and click the two links that you need. The pioneer.ini file should not be blank. Redownload everything from the above URL and see if that fixes things for you.
Posted Mar 16, 2009 · 20:41 UTC#12
Thanks, I actually found it, did it and it worked! Thanks for the walkthrough!
I had done the hardware bypass first, but since I have an Onstar which requires the mute wire--it was making my F90BT reboot! which was an extremely obnoxious thing to do.
Posted Mar 26, 2009 · 01:02 UTC#13
still not getting it. you say dont unzip the the data.zip file, then it says to open the data.zip file. confused as hell.
Posted Mar 26, 2009 · 02:15 UTC#14
Deja-Vu..... :P
Posted Mar 26, 2009 · 03:48 UTC#15
ok i got it but now the unit isnt reading the sd card. NOW WHAT????? Anyone? please!
Posted Mar 26, 2009 · 17:18 UTC#16
i thought i understood that you DID NOT have to ground the parking wire IF you did the software bypass?! i am now understanding differently, assuming this would've been done upon install, grounding the wire that is?!
Posted Mar 26, 2009 · 17:24 UTC#17
when i go (ATTEMPT)to open my data file, its tells me there is not application for this, to run it first. my data icon has the Windows icon on it. do i not have the format correct?!
