Hi everyone,
I'm searching for a while trough this fantastic forum a way to move the Route info and the stopflyover icons.
I first tried the easy way in changing the "y" values in navigatemap_800_480.ui. No luck.
Next, I read a post where the idea was to change values in the two files navigatemap.ui and start.ui.
Unfortunately, I've no idea how to do this.
Can someone tells me how it can be done?
Same with the box showing when you make a call. Can it be moved?
