When I make an outgoing call from my iPhone the number shows as"Unknown" on the navi display. It doesn't show the name of the person that I'm calling. Is there a way to fix this? Works fine for incoming calls.
Posted Mar 12, 2009 · 14:56 UTC#1
does this happen when you use your contacts or voice dialing from the nav unit? or just when you select a contact directly from your iphone?
It happens when I select a contact directly from my phone
I suppose you can call this "normal". There isnt a problem with your unit. Mine does this when i dial directly from my phone as well. I do not know of a fix for this.
Since there was no incoming call with caller ID info, the phone does not send the number dialed to AVIC (it probably wouldn't to any Bluetooth handsfree), so there's nothing for AVIC to show...
