SPEED WARNING
By nicholas24d · Mar 13, 2009in Problems/Troubleshooting💬 6 posts👁️ 1,115 views
Posted Mar 13, 2009 · 02:02 UTC#1
Hi guys i have a f900bt, hardware bypass installed and vss wire hook up on my 2005 Toyota Matrix. my problem is i'm not getting the speed warning...
its on and i set the tolorance level on all the % but same thing....could it be because of the hardware bypass ?
Posted Mar 13, 2009 · 14:29 UTC#2
Mines giving me audio warnings with the default settings.
Posted Mar 14, 2009 · 01:35 UTC#3
did you do the hardware or software bypass? and and is the VSS wire connected?
Posted Mar 14, 2009 · 01:50 UTC#4
It will only work on roads where the speed is provided to the unit in the software. For instance in my area (North-east Ohio) it only works on major highways. Even when it does work I think it is usually off 5-10mph
Posted Mar 14, 2009 · 02:48 UTC#5
Mine is hardware bypassed and VSS wire is hooked up. It doesn't give me audio alers everywhere. I get it on highways and ezpass lanes.
Posted Mar 15, 2009 · 01:37 UTC#6
I'm in toronto , Canada and i never got the warning on all highways and local road/street.
I will try to make sure the VSS wire is tapped properly\
thanks for the input guys!
