navigation signal and xm problems
By elacher10 · Mar 13, 2009in Problems/Troubleshooting💬 5 posts👁️ 862 views
Posted Mar 13, 2009 · 13:29 UTC#1
so i just installed my avic f700bt into my 07 tahoe and i am having some problems. every so often my unit tells me " gps signal lost " and my xm radio cuts out all the time. really annoying.... i have the antennas mounted on the roof of my car under the headliner. any suggestions? let me know thanks.
eric
Posted May 01, 2009 · 16:09 UTC#2
I have same issue, have you found solution ??
Thnks
Matteo
Posted May 02, 2009 · 03:45 UTC#3
Really? Wasn't there another thread on this just last week?
Your antennas need to be mounted on the outside of your car. From what you are describing, it sounds as if you are tucking the antenna between the inside of your roof and your headliner. This method, as you have discovered, will work very, very, very poorly, if at all. Both XM and GPS antennas will need a clear view of the sky to work. Your roof is currently obstructing that view, hence your signal will be very weak and will frequently cut out.
Posted May 06, 2009 · 14:08 UTC#4
the gps antenna can be placed in the car, either on the dashboard or under a dashboard panel if it is plastic only, metal will block the signal. the XM antenna placement is a little more important because there are fewer sats to get info from
Posted May 07, 2009 · 13:43 UTC#5
also make sure they are at least 3 inches away from each other.
