I have posted about this before, but, I now have a video. Has anyone else seen this issue where the speed fluctuates when you're stopped? I think that this contributes to the recalculating issue.
Really, no one else is having this issue?
what did you hook you vss wire up to?
I hooked up the VSS wire to the one coming off the PAC. I am driving a 2008 VW Rabbit.
Nope, thats as fast as a 2008 Rabbit can go.
try disconnecting the vss wire and see if that helps at all. If different voltage is getting through then it may display the speeds based off of those voltage readings
