Please suggest a vent mount for f500bt
By aramis11 · Mar 13, 2009in General💬 5 posts👁️ 1,765 views
Posted Mar 13, 2009 · 17:43 UTC#1
Hi,
i need a vent mount compatible with f500bt. Is there a original pioneer vent mount? Please suggest me a vent mount.
Thank you very much...
Posted Mar 15, 2009 · 21:13 UTC#3
this type of mounts gemeraly fit a lot of car type. i think it is more important to compatibility of f500. But i cant find any product for f500. maybe other f500 owners use this type veny mouınts.
If avic s1 mounting holes(pins) axactly same with f500, i can use monts that compatible with the s1 for my f500?
Posted Jan 02, 2010 · 22:32 UTC#4
I have a 2001 Accord and bought f500bt last week. I have never installed anything like that on my car but the supplied mount looks too big + the cable to the cradle is really thick... It seems like a good idea to remove the clock unit (right between the vents) and make a custom mount fastened to the same spot on the dash. There will be plenty of room to hide the wiring and the only thing to consider is buying a hazard lights switch which could be fixed to the mount. There could be many other options but I believe the clock spot mount would be great. What do you think?
Posted Jan 03, 2010 · 06:52 UTC#5
For my Mazda6, I used top compartment and put audio output (pre-amp) to line driver/amplifier and ground loop isolator and then to Bose head unit's AUX-in. It works pretty well & no engine noise.
I will post some photo later.
