Mute Alternative??
By R3GUL8OR · Mar 14, 2009in Problems/Troubleshooting💬 7 posts👁️ 996 views
Posted Mar 14, 2009 · 21:29 UTC#1
Hey guys, tried doing a search on this but all I kept coming up with is the mute wire or muting the nav voice.
Is there a alternate way (besides just turning down the volume) to mute the 900BT deck (i.e. hack to hardcode a actual button or anything)? Anytime I try to push and hold the knob, 9 out of 10 I activate the voice feature. The other times I actually get it muted I can't get it turned back off. thanks
Posted Mar 15, 2009 · 13:26 UTC#2
no you can;t mute the deck.
however, you could press OFF in the AV source screen with the active source playing. It soft switches it off.
But I hear you; a mute function ought to be there :(
Posted Mar 15, 2009 · 15:06 UTC#3
Mute is available through the wired remote input on back for the steering wheel control adapters. Exactly what signal it takes? I dunno.
Posted Mar 16, 2009 · 04:04 UTC#4
its just frustrating. Every Pioneer deck I have had in the past has had a ATT button of some kind. The whole pushing and holding the control knob for a few seconds to mute it is kinda retarded since the knob is multi-directional. o well. Thanks for the replies guys
Posted Mar 16, 2009 · 16:26 UTC#5
if you really need it, you could always wire in a small pushbutton switch to the mute wire and mount the switch somewhere like the dash kit
Posted Mar 16, 2009 · 17:53 UTC#6
Dont need it that bad. lol. I just thought that maybe with all the hacks people have done like muting the nav voice, someone might have come up with a way to soft code a mute button
Posted Mar 16, 2009 · 19:19 UTC#7
When I hooked my steering wheel controls up and programmed the SWI-PAC for MUTE it works but it is an ATT which controls the master volume down to 03.
