F90 ipod sounds crappy right channel
By achenator · Mar 15, 2009in Problems/Troubleshooting💬 4 posts👁️ 1,015 views
Posted Mar 15, 2009 · 02:38 UTC#1
I have a f90 and when using the ipod connection the right channel sounds low and distorted. It only does this on the ipod connection and sounds fine on all other sources. I noticed this shortly after the software update although the two could also not be related. I am using the cable that came with the unit. Will switching to the apple cable help this? Anybody else having similar issues?
Posted Mar 16, 2009 · 07:20 UTC#2
Since it is only the ipod that does it, it could very well be the cable. If the wire for the right channel is damaged it can cause this. Try a different cable if you have one.
Posted Mar 17, 2009 · 20:53 UTC#4
I took my dash apart while the unit was playing and jiggled the wires a bit. It went back to normal and I couldn't get it to distort again. I taped the connections with the rca plugs with electrical tape -it seems the rca plugs don't fit together very tightly. So far, so good. At least I know if it occurs again it is a wiring problem and not a software or hardware problem and I will continue to approach it as such. Thanks for the help and ideas.
