Amp turn on
By Z06PSI · Mar 17, 2009in Problems/Troubleshooting💬 8 posts👁️ 2,807 views
Posted Mar 17, 2009 · 01:35 UTC#1
Getting a loud pop when I turn the head unit on. It is powering a stock subwoofer in a 2005 Navigator. Any way to soften the pop? Maybe a resistor inline?
Posted Mar 17, 2009 · 03:06 UTC#2
yes add a resistor in line with the amp turn on, ford amp turn on is 5 volts. To avoid the pop, you will need to add a 12 volt to 5 volt regulator in line on the remote lead. This item can be purchased at any Radio Shack, the part number is 276-1770. And yes you can use a resistor but you will need to test for the value it eludes me at the present time.
Posted Mar 17, 2009 · 14:13 UTC#3
just add a 1450 Ohm resistor inline with the remote turn on wire (common with most ford premium sound systems)
Posted Mar 18, 2009 · 01:32 UTC#4
Thanks guys.
Posted Apr 07, 2009 · 14:20 UTC#5
I put a 1.5K ohm 1/2 watt resistor in and the pop is significantly less but it is still there.
Posted Apr 07, 2009 · 16:11 UTC#6
i would try a resistor with a little higher value, maybe 2k or 2.5k, im not sure, 1450 is what we have in our shop and havent had any problems
Posted Apr 07, 2009 · 17:37 UTC#7
What do you do if you have the pop when the amp turns off? Same thing?
Posted Apr 07, 2009 · 18:55 UTC#8
yes
