2007 hyundai entourage infinity - Help
By ozsplace · Mar 17, 2009in Vehicle Specific Wiring💬 2 posts👁️ 892 views
Posted Mar 17, 2009 · 12:30 UTC#1
I found the wiring for the standard radio but I can't find anything about the wiring for the infinity radio. I got a wiring harness and there are a few more wires on the infinity side then the wiring harness side - anyone out there do a infinity install - does the standard wiring work?
Posted Mar 20, 2009 · 21:15 UTC#2
bypass the ifninity amp.
go to the amp, and you should she 2 harnes plugged into it. one is input, one is output. test your wires, and run a jumper wire from the 1 harness to the other.
