Ok so here is the deal and i have been doing my research i just want to know if this is right. I wanna add this feature to my existing data.zip file and i found this and this is what boris said.
in SYS.TXT, find [debug] section and add a line, if it's not there:
speedcam_enabled=1
Then:
extract the file from the attachment to SD card and copy ui_pioneer folder to APL2\iGO.
You will have settingXXX.ui files (to turn speedcamera functions on and off) and placeXXX.ui files to add/edit cams manually.
So basically i am gonna take my sys.txt off my avic and add this line then copy the new sys.txt back to my avic.
Then at this thread page 3 halfway down there is a setting.rar file you can download and the question is do i take the data.zip file that is already modified to my liking and overwrite the ui_pioneer file to the data.zip then put that back on my avic. viewtopic.php?f=34&t=19523&hilit=speedcam&start=30
And the obvioulsy do this Copy the two safety cam database files - "Red_Light_Camera_us.txt", and "Speed_Trap.txt" to: MyFlashDrive\APL2\IGO\Content\SpeedCam
So the question i have is should this work adding all this to my existing data.zip that is mavs....
