Can you add backgrounds to an avic N2?
By israelmartin · Mar 18, 2009in Custom Backgrounds💬 3 posts👁️ 2,171 views
Posted Mar 18, 2009 · 16:30 UTC#1
I just wanna know if you can add backgrounds on my pioneer N2.
Posted Mar 20, 2009 · 00:28 UTC#2
You need to create a Folder on a blank CD, name the folder BG
You can put up to 20 images (only .jpg files 2048x1536 max pixels, and name only with letters and numbers) in that folder, (you can put less than 20 images if you want)
Then add anything besides music (mp3 or audio data) so at least 100 MB of data is burned onto the CD, but not in the BG folder (I just put a bunch misc stuff, including the .pdf files for the owners manuals of all the stereo equipment in my car)
Insert disk into your N2
In the Nav menu,
touch Settings
touch System Options
touch Background Picture Setting
touch either AV Background or Navigation Background
touch the Import from disk
The files in the BG folder will be listed, touch the picture you want
After you select the picture it will ask you if you want the picture to "Center" or "Repeat"
Touch Done or Select another Picture or Change to another background
Easier than pie
Posted Mar 20, 2009 · 15:10 UTC#3
Thanks man, i just did it and it worked beautiful. !!!!!!!!!
