Hi all!
I searched the web and just found this great forum. So many problems are solved and I hope you guys can help with my too.
I decided for the F900bt (2.0 update already installed) and installed it in my 2008 Dodge Grand Caravan (w/o factory amp or steering wheel controls). To replace the head unit I installed the PAC C2R-CHY4 replacement interface. That was a pretty easy thing, all wires connected and GPS and Mic installed - everything works fine.
Until I realized later that the radio turns off and restarts randomly when I open or close one powered window of the car. It doesn't matter which window it is and it don't happen each time. But of course I want to stop that. So I thought maybe the PAC interface module has an issue and sent it back to the seller and bought a another one. You can imagine - the same issue with the new interface. I also checked again all wire connections and couldn't find any issue here.
Do you have any idea what can cause the issue?
Thanks in advance!
Virzn
