Hello everyone,
I just purchased the AVIC-F700BT and started installing it. I bought a Metra wiring harness for my 06 Civic and connected all the wires. I did the hardwire mod to allow video playback without the handbrake. I tested out the unit last night and so far, the radio work perfectly but when I tried to test the video playback, I got the warning screen, pressed ok, and the video started playing. Actually it had started playing even with the warning screen displayed. Sound was good, I could fast forward, etc. but there was not video. I will double check the grounding for the mute wire (already moved) and the handbrake wire. However, I would have thought that if the grounding was not correct, that it would not even play the movie. I will also try another MP4 video since I only tried a Heroes S1E1 that I got from a buddy of mine. I don't know what the resolution is but it plays fine in my PSP. Not sure if the video resolution might have been the problem. Anyway, just curious to see if anyone else had seen this problems and might be able to say... oh yeah.. that is simple.. just have to do this... Definately wnat to make sure all my wiring is correct before I button up everything. PS. I was able to bring up the GPS map while the movie was playing.. not sure if that help at all. I also spent several hours searching through the forum and re-reading the operation guide.
Thank you in advance for all your help.
Rich
