toop said:
Hmm...so it won't really "dry" if I just put it on the ends of the break....only until I put the two ends together?
Actually it does dry pretty quickly, in a matter of seconds, so you want to be pretty quick as soon as you dip the small paintbrush into it. The joint will also hold together as soon as it dries, but since it softens the plastic, I'd wait overnight before using it.
If you can find some, get some scrap pieces of ABS plastic and play around with it, it's pretty cool. The unused pieces from an installation kit should work for practice. I use solvent welding for custom fabrication. It's nice because I don't have to worry about it cracking or seperating like Bondo or fiberglass could.
Here's the trim ring, it's kind of pricey. Probably looking at $20 shipped. Ebay might be cheaper, but sometimes not!
http://parts.pioneerelectronics.com/par ... um=CNS8298
