Sound when reading disc after cndv80mt upgrade
By Tallessi · Mar 20, 2009in Problems/Troubleshooting💬 4 posts👁️ 730 views
Posted Mar 20, 2009 · 20:30 UTC#1
I download. extracted. and burnt new cndv80mt disc. i put it in my avic d3 and it upgraded. everything seems to be working fine, except now im getting noises every time the disc is reading. noises that are heard through speakers. i used a verbatim dl disc. previous disc that came with it did not make that noise so i know its not my speakers or amps. thank you to anyone who can help
Posted Mar 23, 2009 · 22:22 UTC#2
i used the tdk dl disc and its seems fine. it definatly loaded up faster. burned with imgburm 1x
Posted Apr 02, 2009 · 02:30 UTC#3
I'm having the same problem... I'll try burning it again tomorrow at a slower speed and hopefully it will work.
Using Memorex discs btw.
Posted Apr 02, 2009 · 13:37 UTC#4
Ok fixed my problem. It wasn't an actual problem with reading the disc, as it was a problem of the system making any sound at all. If I pressed a button I would get some static thing, and if I tried to get voice navigation it would just be static.
Restored the factory defaults and it worked fine :D
