Is it possible to use iPod without the RCA connection??
By striker222 · Mar 21, 2009in General💬 12 posts👁️ 2,185 views
Posted Mar 21, 2009 · 01:07 UTC#1
I messed up on the install of my AVIC-F90BT, I thought all I had to do for my iPod to connect was use the regular USB cable. Didn't realize the AVIC uses the audio/video input for sound from the ipod, and the usb for control. Is it possible to get the music to play via USB only? It works on a flash drive, why not the iPod? I took my time doing a nice panel-mount usb connection for the iPod, and it's useless unless I can do this.
Posted Mar 21, 2009 · 01:21 UTC#2
not with USB only. you can use, like, a 3.5 - 3.5mm plug, for say the front input, but that's all
Posted Mar 21, 2009 · 05:52 UTC#3
^how do you use the front plug? I have the aux cord and still cant get it to play
Posted Mar 22, 2009 · 01:42 UTC#4
Get the proper Ipod cable and connect the RCA's up. You will be glad you did in the end.
Posted Mar 22, 2009 · 21:58 UTC#5
I tried using a regular 3.5MM male X 3.5MM male patch cable from the ipod to the aux in front jack. Didn't work, can anyone explain this?
Posted Mar 24, 2009 · 23:46 UTC#6
I did the very same thing on my first install. You get the info on the screen fine and can control the iPod, but no sound. I know this isn't what you want to hear but I would HIGHLY recommend opening back up and fixing it properly. I am sooo glad that I did - the iPod control is one of my favorite features. Besides you bought an all-in-one so you wouldn't have all of those external wires everywhere
Posted Jun 25, 2009 · 01:39 UTC#7
So im still confused.
Im going to have my f90bt installed tomorrow.
If i want to use the ipod manually without the touch screen through the front jack
what do i have to do for it to work?
Posted Jun 25, 2009 · 03:12 UTC#8
plug it in.. that's it..
Posted Jun 25, 2009 · 05:19 UTC#9
If you're in iPod mode, it's only going to take audio input from the rear inputs. You'll have to use only the 3.5 front jack with the iPod not connected to the USB (so you can control with the iPod's buttons) and set the AVIC to front aux as source.
Posted Jun 25, 2009 · 06:13 UTC#10
Just go to Radio Shack and get an 1\8 inch A\V cable. It will have three black bands on the plug. On the unit, switch AV2 to on.
Posted Jun 29, 2009 · 19:06 UTC#12
READ THE MANUAL. The front 3.5mm input is a A/V Input compatible with the External Input Cable (sold separately). If you plug a regular patch cable into it, it doesn't seem to work. I've tried. Several times. And then I read the manual.
There may be other ways to bypass it, but reading the manual is ALWAYS a good place to start. It's a PDF and very easily searchable.
Page 42 and 43 in the Owner's manual, available on Pioneer's website.
