Hey guys,
Like most of you I've had my F90BT since it came out and with the 2.0 firmware it's really helped a lot of issues. I do still have a couple nagging issues I wanted to ask the group if they are experiencing at all.
1. When I play IPOD normally (no navigation) it plays perfectly not sounds quality issues. However I've noticed that when I have navigation going that I get somewhat frequent stutters(1/2 pauses) in the IPOD playback. For the most part it seems to be when the navigation system is recalculating or zooming in a lot. I am guessing this is just another example of weak cpu or bad code, but I wanted to find out if others are having the issue.
2. I seem to be cursed when it comes to IPOD cables. I've gone through 3 of them with different issues. The current one I have for some reason every once in awhile when I start my car the right side audio output is virtually non-existent if I slide the sound to right I can barely hear whispers. I know it's not the speakers b/c they play just fine from other sources and from IPOD sometimes too. The only way I have found to fix the issue seems to be to unplug the IPOD-USBtoUSB connector piece. Once it's plugged back in I immediately get stereo sound again. If I just disconnect the IPOD from the IPOD connector this won't work, I'm not sure why, but I've tried several times it only seems to "fix" itself if I unplug the usb portion. Just FYI all my cable are tight on the back of the unit and they are not stretched or pinched I have lots of excess cable. I'm guessing I just have "another" bad IPOD cable. I'm curious has anyone found any GOOD quality cables to use out there? I don't mind paying extra I'm just sick of these issues with bad quality cables.
Thanks for the help,
Tambu
