My F700BT won't remember FM/ AM Settings
By xJ2Mx · Mar 24, 2009in Problems/Troubleshooting💬 8 posts👁️ 1,144 views
Posted Mar 24, 2009 · 02:43 UTC#1
Like the subject implies. My AVIC-F700 has never remembered any of my FM Station presets. Everytime I take the key out of my ignition or turn my car off and back on, it's like the unit refuses to remember any of the stations. For example, here in Boston i have 94.5 JAM'N set for just preset 1. I turn car off and back on or i turn it off and turn it on in the morning and it does not remember it. It does however remember that password i set, my bootup screen, my Home address etc. I does not remember the radio station presets or any audio settings such as Loudness being on. Anyone shine some insight on this? It would be greatly appreciated.
Side-note: My HD Tuner when i had it hooked up (i get static due to Antenna sometimes i believe), it remmeber my HD Stations.
Posted Mar 24, 2009 · 02:45 UTC#2
You need to connect your acc wire to a constant power. There is something wrong with your connection.
Posted Mar 24, 2009 · 09:37 UTC#3
Sounds like you don't have the permanent +12V hooked up, which is required to retain memory. There are 2 power connections to the unit that should both be hooked up correctly:
Yellow wire - Should be hooked up to an always on +12 source
Red wire - Should be hooked up to a switched +12 source
Posted Mar 24, 2009 · 09:53 UTC#4
OCCASIONALLY (!!!!) this is switched the other way around.
But yes, it is a clear indication of not having constant power (in order to store presets of the radio and sound settings)
Posted Mar 24, 2009 · 11:51 UTC#5
I will check again however I used both a car manual and a multimedia however I'm sure it must be because otherwise I'm sure other people on this forum would of said the same things Ihave said. Thanks for the response I'll inform you all how it goes
Posted Mar 24, 2009 · 15:14 UTC#6
Get a simple 10 dollar V meter from home depot or hardware store and hook that up. That way you are always sure having the correct leads, and checks your grounds.
Posted Mar 27, 2009 · 23:56 UTC#7
For anyone else with this issue. Check your Switched and Constant wires. My Eclipse was preowned and even though I used a multimedia and test light, i switched the yellow and red wires and taaaadaa! It works perfectly. Must mean the guy did his own wiring. Lol. Thanks for the insightful comments and help everyone.
Posted Mar 28, 2009 · 08:55 UTC#8
Glad it's fixed,... :D
