whtcrxghst said:
Its not recommended--but, Pioneers CDBTB100 will hook-up to anything P-bus. The interface is bad so I wouldn't bother if I were you
pontiacpassion said:
I've been looking around and I'm assuming that AVIC d2 is not blue tooth compatible am I right?
If you don't mind having the basic handsfree features w/o the bonus' of phonebook entries then it's not bad.
Pros: It works! You can do voice dial,redial last 3 in/out coming. even though you don't see the entire number all the time you can get full redial.
Cons: I have yet found a Motorolla to AUTO connect after turning it on. Nokia will Sony Ericsson will and LQ (Except the Choc). once the conversation is over you have to go back to whatever source you were listening to.
As long I can make and recv calls I'm not stressing. Now if they can make a better harness for the Motorolla HF1000 for my Armada then I will sell the BT module and get the HF1000. It talks to you holds numbers and all that. but the harness they tried out would not work.
But overall with the exception I have to MANUALLY connect I'm cool with it.
