iPod Touch DOESN'T Charge
By Stigy · Mar 26, 2009in General💬 10 posts👁️ 5,446 views
Posted Mar 26, 2009 · 14:10 UTC#1
So from reading these forums my 1st Gen iPod Touch should charge via my Avic-D3 and the iPod cable, but it does not charge at all. I made sure that the connector on the back of the D3 is nice and secure and still no luck charging the iPod Touch.
My other question is that when I get in my car with the iPod Touch plugged in (while the car was off) I need to open my glove compartment and slide to unlock before the D3 is able to read the music off the iPod to be able to play it.
Anyone have any insight?
Posted Apr 01, 2009 · 06:37 UTC#2
go to your settings in av mode and look for the ipod charge selection... it should say ipod charge on or off..
Posted Apr 07, 2009 · 04:20 UTC#3
My 5G video charges just fine. It doesn't charge the iPod Touch.
Posted Apr 08, 2009 · 15:02 UTC#4
The newest iPod touch, iPod nano, and iPhone 3G do not charge via the cable to the D3. The cable is firewire-only, and the new iPods and iPhone only charge via USB.
Posted Apr 12, 2009 · 01:03 UTC#5
Yes i understand the newest iPod Touch does not charge via the cable, but as stated in my origial post my iPod Touch is one of the original ones from when they came out, so thats why im confused as to why itdoesnt support it.
is there any other chance of Pioneer releasing a cable that will charge the newer ipod touches on the d3 in case i plan on getting an iphone soon.
Posted Apr 23, 2009 · 22:17 UTC#6
Cablejive.com has an adapter that will charge the iPod touch 2g. The one made by scoche doesn't work.
Posted Apr 29, 2009 · 15:01 UTC#7
Yes I understand all the cables that are released and whatnot, but my iPod Touch is a 1st generation.
Not a 2nd generation iPod Touch, which I know doesn't charge via the D3.
My iPod 5G Video charges just fine on my D3, but my iPod Touch 1st Generation does not charge on my D3.
Anyone?!
Posted Apr 30, 2009 · 03:29 UTC#8
I have the Pioneer D3 , and I have the Ipod Touch FIRST Generation (32gb) ... mine charges just fine .
There are two charging options, I forget where it is you goto, but you must click on "ipod charge" to "ON" in order for it to charge, also by having the "charge on" status, you do not need to unlock your ipod touch each time, this irritated me a lot also at first, then i found that solution...
hopefully that helps, if not, send me a private message and ill send you my email/IM if you need more help.
-brad
Posted May 03, 2009 · 05:15 UTC#9
OK I have an AVIC D3 and I have BOTH the first gen iPod Touch, 2nd Gen iPod Touch as well as an iPhone 3G.
1st gen iTouch charges by using CD-I200 cable and nothing else.
2ng gen iTouch charges by using CD-I200 & Scosche Passport.
iPhone 3G charges by using CD-I200 & Scosche Passport.
I have personally tried them all myself and they worked just fine. As stated earlier in the thread you need to make sure that you go into the settings and turn the iPod Charging ON.
CD-I200
Scosche Passport
Posted May 04, 2009 · 18:31 UTC#10
Okay well after a ton of looking around I finally found a buddy with an iPod Touch and his charges in my car so it must be something wrong with my iPod...
ugh...
