Installing Z1 in '05 F250, wiring help please
By ducatiboy · Oct 17, 2006in General💬 17 posts👁️ 5,015 views
Posted Oct 17, 2006 · 22:38 UTC#1
Hi all,
A friend of mine wants me to help him install a z1 into his F250. Couple wiring questions (f250 related). I'm going to double post this in the specific car wiring too http://www.avic411.com/forum/viewtopic.php?p=15037 since I have to do this on thursday and I hope who ever knows this stuff will see it :) Maybe with my mod status I won't get chastized too much. ;)
I wanted to know:
1. reverse wire, in http://www.avic411.com/forum/viewtopic. ... light=f250 cntrylvr79 says that it's Reverse Light black/pink + back of fuse box, black 8 pin plug. Is that correct for a 05 F250?
2. VSS wire. Anyone know where the easiest place to tap off this?
3. The wiring harness has a positive dimer. Will that work hooked to the Z1's ILL wire? Will it work without my circuit?
4. Any ideas about placement for the GPS and Sat antennas? Where to route them and place them?
Thanks for any help guys!
Steve
Posted Oct 18, 2006 · 00:49 UTC#2
Steve,
Glad you're not too much of a god! seriously...
I don't have an F250 BUT given it's a Ford, you've already done most of this on your Navigator...
3. If it's the same as the 05 mustang (which I'm almost certain it is)... won;t work, you'll have to pull it from the actual switch
4. GPS sits on the roof, runs down the inside... you *should* be able to run the cable thru the top-mounted stop-light without any problems, thru the main cabin and to the radio at the front.
Andy
p.s. I might just hit you up for one of those amp turn-on deals in the VERY NEAR future (do I get a discount?)
Posted Oct 18, 2006 · 01:32 UTC#3
Thanks, I never said I was a God :) And I don't know the location of specific wires in specific vehicles. People email me for info like that and unless they ask me about my vehicle, I can't really help them.
And actally I have an Aviator, not a Navigator. It's the fancy Explorer (or the poor man's Navigator). And all the wires I needed were right there at the radio: ILL, VSS, amp turn on, steering wheel controls etc. But the F250 doesn't have any of that. I know I could hunt them down with time, but I thought someone here might know exactly where they were and might want to help me out a bit :)
Posted Oct 18, 2006 · 01:38 UTC#4
Yes the reverse wire is the same for the 05 f250.
Speed Sense gray/black radio harness or ABS module, pin 21
Notes: The ABS module is in the driver side rear corner of the engine compartment.
I'd say pick it up at the radio much easier. As for the illumination, I've not had any luck using the dimmer so I just get it at the headlight switch. It's the brown wire.
The gps and sat antennas I had to put on the roof of the truck in order for them to work. I'm sure some people have had luck with them on the inside, but not I.
All in all good luck and happy installing, not a hard truck to deal with. By the way I'm catching up with you. Only 600 odd posts to go. :)
Posted Oct 18, 2006 · 03:33 UTC#5
Where might I find actual wiring diagrams for ford F150 to confirm VSS, ILL, etc?
Thanks,
JSB123
Posted Oct 18, 2006 · 03:34 UTC#6
Yes, I meant F150, not F250 as in previous poster.
Posted Oct 18, 2006 · 03:43 UTC#7
Thanks... makes you feel like you have no life huh? :D
Posted Oct 18, 2006 · 04:10 UTC#8
f150 is the same. vss is in the radio harness. actually a very very simple install, dont sweat it.
Posted Oct 18, 2006 · 04:52 UTC#9
Yeah pretty much. On the positive side though, there's some very happy people floating around with their avics hooked up properly.
Posted Oct 18, 2006 · 05:19 UTC#10
Steve,
I just installed my Avc Z-1 in my 2005 F250....it was super easy with a dash kit, wiring harness from Circuit City and wiring info from [url=http://www.the12volt.com">www.the12volt.com (
Posted Oct 18, 2006 · 05:25 UTC#11
Steve,
I just installed my Avc Z-1 in my 2005 F250....it was super easy with a dash kit, wiring harness from Circuit City and wiring info from www.the12volt.com I have never installed anything electrical in a vehicle, so you know it had to be easy if I accomplished it without a problem :D I just ordered your bypass circuit, but have not installed it yet...just haven't had time. It looks like most of your questions have been answered, but just to throw in my $.02 I found the reverse wire by pulling out my fuse box and going from there. It was a black wire, with pink on it...but the pink was more purply than pink. I found at least two other wires that were black/pink, so I just used the one from the fuse box. The VSS wire, I just spliced in behind the wiring harness from the vehicle. I hooked up the AVIC's illumination wire to my dimmer wire, and it works fine....but again, I haven't installed your bypass yet (my AVIC is pre-June '06) And lastly, I put my GPS antennea under my dash. When I took out the radio, there is a bar straight in. I put the antenna on that bar just to the left of the air vent. It works perfectly =) In a couple of weeks I have to pull apart my dash to add in all the extras I recently ordered, hopefully that will go as well as the headunit install! Good luck with your friend's F250.
Michele
Posted Oct 18, 2006 · 17:04 UTC#12
Hey... they're almost the same (sortof)
Hope the install went well.
Andy
ps Check you pm
Posted Oct 18, 2006 · 19:17 UTC#13
Hey cntrylvr79, do you know if the VSS wire is in the radio harness for a 2005 Ford Escape with the Mach 300 stereo (in dash 6 disc changer). And what about where to find the parking brake and reverse wires? I still haven't hooked up those three (yeah, I know I'm being lazy LOL)
TIA,
Posted Oct 18, 2006 · 19:56 UTC#14
2005 ford escape
Reverse Light black/pink + driver kick or SJB, conn. C, pin 10
Notes: The SJB (Smart Junction Box) is the fuse/relay box on the passenger side of the center console.
Parking Brake lt. green/red - switch or SJB, conn. D, pin 13
Speed Sense gray/black ABS or brake system control module
Notes: The ABS control module is on the rear driver side of the engine compartment. On the Hybrid models, the brake system control module is on the rear passenger side of the engine compartment.
On vehicles with the 6-disc in-dash CD changer, this wire is also found in the radio harness.
Merry xmas.
Posted Oct 19, 2006 · 03:18 UTC#15
Cool, thanks. I'm guessing that the wire will still be gray/black behind the radio? What kind of signal should I get, so I know if I find the right wire or not.
Thanks again.
Posted Oct 19, 2006 · 03:34 UTC#16
If you meter it, set the meter to a/c and the reading should fluctuate as the car's speed changes. Or if you don't have a meter, you can hook into that wire and check the speed pulse count on the z1. It'll go up when moving if you got the right one. That gray/black wire is or should be the only gray/black in the harness.
Posted Oct 24, 2006 · 13:20 UTC#17
I've probably installed about 50 AVIC's in the F250/350 trucks, seeing as we have a huge truck accessory dept. I have been putting systems in a buttload of these trucks lately, and I have had no problems with putting the GPS and XM antennas inside, behind the radio, on top of the a/c duct to the right of the radio opening. I use the piece of metal that comes with the GPS antenna, and it works fantastic. As far as any other questions, it looks like they were all answered, and then some. I've also been using the circuit you got there for the Z1, and kudos, DB, kudos....the tr-7/vt-3 combo is a pain. Thanks for making my life easier. I install about 10 Z1's a month on the average, so it's been a huge help.
