N2 noise with RCA connection to ipod
By Daddytony · Mar 27, 2009in Problems/Troubleshooting💬 6 posts👁️ 1,270 views
Posted Mar 27, 2009 · 16:53 UTC#1
Hi all,
I came across ipod RCA cable for next to nothing and I have decided to give it a try by connecting it to the N2 hide away unit. I have RES and it is set up to view from n2 and my n2 can see what's playing in RES. I bought three Y adapters to run all the wires. The only way I can see and hear my ipod was to power on my RES and selecting aux input. Now the problems: the video quality is very poor. I know it's not the RCA wire as when I connect my ipod to my tv, it looks great. The worse thing that I have noticed is the noise- it sounds like alarm clock going off with fast beep, beep, beep, beep,(pause), beep... beeping noise only gets louder as I turn up the volume. Am I doing something wrong here? Any feedback would be much appreciated. Anton
Posted Mar 31, 2009 · 14:22 UTC#2
I have the N4 with the iPod adapter but I had a similar issue with noise. I always had noise and I thought it was the iPod cable. I have a 30GB video btw. I figured out it was the backlight on the iPod creating the noise. Everytime the backlight shut off I had noise. I went to the options and made the backlight never shut off. No problems since.
Try it, it may help.
Posted Apr 05, 2009 · 00:05 UTC#3
Hello there,
That sounds very interesting. I am going to test that out. I thought that due to my wire connections, I ended up looping the RES to AVIC to the IPOD. I would let you know if that takes care of the problem. Thank you for your reply.
Posted Apr 09, 2009 · 13:29 UTC#4
Hi twofiftysx,
I've tried what you suggested but it didint make much of differece. Thank you for your input
Posted Apr 22, 2009 · 20:23 UTC#5
It sounds like one of your problems may be having two sources connected to your N2 at the same time. Try ONLY connecting the iPod to the A/V inputs on your N2, and see how that does. Then we can go from there...
Posted Apr 28, 2009 · 19:43 UTC#6
Hi Jimmy,
Thank you for your input.
I've tried connecting the ipod alone and I still have the same beeping noise. I have ordered the noise filter and it just lower the ipod volume without affecting the beeping noise. What I have notice is that when I select the AV, even my ipod was not connected, I can hear the noise. I have never had any issues playing RES or playing DVD from the head unit.
