NEW UNIT SEALED VS UNSEALED
By rsxtype-t · Oct 17, 2006in General💬 23 posts👁️ 3,653 views
Posted Oct 17, 2006 · 23:40 UTC#1
i just bought my D2 off ebay from a reputable seller that some members here referred me to. they said they all got their brand new SEALED and the auction itself said the unit is brand new.
i just got it today but i don't see a seal anywhere? it's just a D2 pioneer box..no wrapping, no stickers on the box covers. the D2 itself was in the usual foam electronic bag but it wasn't sealed either.
also, i can see some of the metal on the metal cage around the unit "brushed"..i don't know if thats how the metal's texture is or if it was installed previously.
can anyone tell me if this is normal? when compared to D2's bought at retail chains or 100% new D2's, does it come sealed at all?
i'm worried this can be false advertising and my unit is indeed a refurb or remanufactured blah blah
Posted Oct 18, 2006 · 00:15 UTC#2
There is no tape/sticker/seal that actually seals the box when it leaves Pioneer so you could have gotten a brand new one. Look at the little black screws that hold it in the cage--most installations require taking those out so if they are scratched up from the screwdriver, you can assume its used
Posted Oct 18, 2006 · 00:21 UTC#3
the black screws look untouched but someone could've gotten new screws?
i inspected the unit further..the UPC on the D2 doesn't match the UPC on the box. but the serial# sticker on the unit matches the one on the box..but it's just stickers..
don't know if this is normal or not. really not feeling too confident about this purchase as being new anymore..
also no plastic film to protect the LCD screen..one would expect a new unit to have one.
Posted Oct 18, 2006 · 01:26 UTC#4
There is no plastic film over the screen either. Just comes in the styrafoam-like bag thingy
Posted Oct 18, 2006 · 01:49 UTC#5
I was thinking the same thing when I got my D2.
There was no seal on the box, and no plastic film on the screen.
However, everything looked brand new, and having ordered it from Crutchfield, I was not worried in the least bit.
What was the sellers ID that you bought it from? That could tell a lot of whether its new or not. A big time Powerseller is not going to take the time to buy new screws, and even if someone did, they still have to screw the screws in using a screwdriver, so that wouldve scratched the screws. Personally, if the unit looks brand new and all the wires are in neatly coiled, I would assume its new. Very, VERY few people would go through everything that would be required for it to look new.
Posted Oct 18, 2006 · 02:59 UTC#6
the seller is hifiaudioonline. he is a powerseller.
at first i was confident that the unit was really brand new and might still be brand new.
but some things just don't add up.
why would the UPC codes not match the unit and the box? why would he say he doesn't have the manufature month/yr when i asked him..but it says the date on the outside of the box?
the cage looks installed however the black screws appear fine.
and how come a new D2 is almost as cheap as a refurb'd D1 and less than a new D1?
Posted Oct 18, 2006 · 03:16 UTC#7
I have bought from hifiaudioonline before.
They are extremely trustworthy and they are not the type of sellers who would do all the extra work that would be required to make it appear new if it were used.
I would believe them that it is new just as much as I believe Crutchfield that my unit was new.
I have no idea, but I have to take my D2 out on Friday, so I'll check the UPC on that with the UPC on the box and let you know if someone else doesn't have an answer.
There could be a couple of reasons:
a) From what I understand, they have a HUGE warehouse full of inventory and might not be able to check the date on the unit.
b) Depending on the number they have in stock, they may not have known which unit you would be receiving, and therefore they were not able to give you the info.
I have wondered that for some time, and I have absolutely no idea.
Posted Oct 18, 2006 · 03:26 UTC#8
thanks for your insight. and if you can compare the upc's while you're pulling your D2 out..it'll help answer some thoughts.
i'll probably get a unit from circuit city tomorrow and compare them. might sound like i'm extremely anal but i don't like the fact of paying so much for something that might be used.
but on another note, can't wait to get this installed! i got all my accessories ready - dvd player w/ built in tv tuner (still need an antenna), remote, rear cam. the whole package for just about $900. hope the install isn't that much more difficult than my 8600mp with the extra wiring.
what do you guys use to conceal the unit when parked? the positioning of the radio in the rsx is quite attracting to thieves..
Posted Oct 18, 2006 · 04:06 UTC#9
first off, dont take this as an insult, you cant expect to get everything perfect from an ebay auction. I dont care what it is, nor who sells it. As far as not giving you the manu date that could be and probably is just that they didnt want to take the time to look. I wouldnt, because that isnt something that would matter in all honesty. It is just a hassle for someone to go an take that time. You seem to be so anal for a unit that appears to be around $500 while that isnt chump change, its kind of ironic to be hopped up so much for what it is. You havent mentioned anything that would be damage, nor have you mentioned the unit doesnt work. Soooo maybe instead of going off and worring so much about it, and spending the time and money down at circuit city buying and returning and whatever, install it and see. If it doesnt work, then you know why you should probably buy from an authorized dealer. If it works, then well your excitement about it possibly being used is meaningless. afterall, the goal was probably to get a good looking, good working, inexpensive unit and if thats what it is, well then take it and run be happy.
Posted Oct 18, 2006 · 15:42 UTC#10
I bought mine from HIFIonline. Everything looks new. I have installed for over a month now. Everything is working. I never check the UPC so i couldnt tell you. But i did register it with Pioneer...so far so good
Posted Oct 18, 2006 · 22:53 UTC#11
I just got mine today from an online seller not ebay and there was no seal on the box. If all the cables are bagged odds are its brand new.
Posted Oct 19, 2006 · 00:19 UTC#12
Just got mine today also. Purchased it through ebay and like everybody else's, there are no plastic wrapping on the unit. It's neatly packed, all cables on plastic bag and looks brand new. I will have it installed this coming Friday.
Posted Oct 20, 2006 · 14:09 UTC#13
who cares if its sealed or not. the very fact u bought it off ebay means it's not pioneer "authorized" so it wouldn't make a difference should you have issues with it. if it looks good and works, thats all that matters.
Posted Oct 20, 2006 · 14:41 UTC#14
its just amazing how a penny pincher will pick the imperfections out of anything. Mom always said "you get what you pay for" so if you think you got a deal right on, if you think you got screwed, its your own damn fault.
Posted Jan 02, 2008 · 04:49 UTC#15
Sad but true.
Posted Jan 03, 2008 · 02:04 UTC#16
pioneer wont give you support anyways, since you bought it off ebay. I called up pioneer about my sat tuner not working, before they'd help me they asked who I bought it from. And when I told them they said "ok" and helped me out. Then I asked him why he asked and he said they wont help anyone if they didn't buy it from a pioneer authorized dealer.
Posted Jan 03, 2008 · 02:31 UTC#17
Give a link to your auction, because you may have gotten a factory refurbished unit. It is very hard to find a D2 brand new now-a-days. If you got a factory reburbished unit, then the seller was correct at saying sealed by the manufacturer. I got a refurb myself and it came packaged the same way you described, but the boxes were pioneer lable boxes and the unit was securely bubble wrapped and well protected. Reread the auction page and make sure you got what you paid for!
For example, on this D2 auction from the seller you bought yours from, at the top, it is list as New, but if you READ the entire page, it clearly states, and I quote: "* Refurbished and SEALED by the manufacturer. This unit is a manufacturer Class "A", Quality Refurbished and SEALED by the manufacturer, Unit appears NEW in new brown box, and is guaranteed to work perfectly. This Unit Comes with ALL accessories supplied by the manufacturer..."
http://cgi.ebay.com/PIONEER-6-5-MONITOR ... dZViewItem
Posted Jan 03, 2008 · 02:41 UTC#18
OH wait, just notice this is another thread from 2006! Who keeps resurrecting these old ass threads?!
Posted Jan 03, 2008 · 02:44 UTC#19
Sad but true.
This guy, that's who! Somebody get me some rope and some gasoline. We're gonna have us a little party.
Posted Jan 03, 2008 · 03:43 UTC#20
Sad but true.
err wtf! I just added to the old thread spamming by not seeing it was from 2006!!!!!!!! :twisted:
Posted Jan 03, 2008 · 06:27 UTC#21
Sad but true.
Yes you did. :lol:
My bad on bringing it back. :oops:
Posted Jan 03, 2008 · 06:41 UTC#22
christ!
Posted Jan 03, 2008 · 09:26 UTC#23
Funny chit :lol:
