Screen Calibration Issues
By NavyHoldi99 · Mar 29, 2009in Problems/Troubleshooting💬 3 posts👁️ 804 views
Posted Mar 29, 2009 · 02:03 UTC#1
Hey all. For whatever reason...the screen calibration on my F900BT is jacked up and I can no longer navigate the screen correctly. I've reset the system but no luck. I can get into the screen calibration menu by holding down the menu button...but I can't progress to the actual calibration because I can't select the stupid "ok" option to proceed (why that is required in the first place is absolutely retarded). I'm using the stylus, as well.
Any ideas? Reading the manual doesn't help much. I can't navigate to the "restore to factory defaults" option and I just had it installed yesterday so I'm don't know if there are other ways to restore the system. I've also searched the forums but haven't found much help from searching "calibrate" "calibration" or "reboot."
Thanks in advance.
- Brett
Posted Apr 24, 2009 · 00:15 UTC#2
Have you found a resolution to this? Same thing happened to me out of nowhere yesterday. Stable install since this past summer, then boom, calibration is way off. And the whole "if you're having issues tapping your screen or with responsiveness to screen taps, tap the ok button below to continue with calibration" WTF?
So frustrated as to why isn't screen calibration the first thing that this device wants to do after a hard reset like EVERY OTHER WINCE DEVICE! so frustrated.
I've disconnected the HU and am hoping it's internal battery drains and it forces a reset in the morning, if not, any advice you've had from the experience would be most appreciated. It sucks because I can't even use testmode because after exiting the copy utility I can't exit the screen behind it.
Posted Apr 24, 2009 · 00:23 UTC#3
Once you get to the tap ok to continue thing have you just tried to keep hitting diff parts of the screen, like start at the button and work out from there, might be able to find the spot that it THINKS the button should be and go from there.
