hello everyone i recently purchased a new car and it came with a avic z1 and the previous owner has a bunch of music that i want to get rid of how do i go about deleting the songs? i've searched but never came up with an answer. thanks in advance
deleting songs..
If you want to get rid of ALL the songs, you can do a level 4 reset. this will reset the unit back to factory defaults like new.
Completely returning the navigation system to the initial state
To return the entire navigation system to the default or factory settings, initialize the navigation system in the following order:
1 Turn the ignition switch off.
2 Press RESET button.
3 Start the engine. After a few moments, the start-up screen comes on for a few seconds.
4 Touch and hold MAP button while the start-up screen is displayed. “Clear memory screen†appears.
5 Touch [Clear user information from hard disk].
-This reset operation clears all music data recorded in the music library. Note that the cleared data cannot be restored.
6 Touch [Yes]. The user area in the hard disk drive is initialized.
After that, the navigation system restarts.
7 Press MENU button and then touch [settings]. The setting menu appears.
8 Touch [Hardware] and then touch [3D Calibration Status].
9 Touch [Learning Status] and then touch [Reset All].
