Lock up in test mode.
By rbrite · Mar 30, 2009in Hacks/Mods💬 3 posts👁️ 836 views
Posted Mar 30, 2009 · 06:21 UTC#1
I did lots of searching on these boards and others and I cannot seem to find anyone having the same issue. Just installed my new F700BT which came with 2.0 firmware loaded. I want to get into test mode to copy the data.zip and start to work on some mods.
I downloaded the .zip file from the FAQ sticky put the files on the SD. The unit boots up, goes into test mode and copies the files. The copy progress bar stops and what is left is the copy window left open with the windows start bar on the bottom.
Now, soon as I touch anything it locks up. If i try to X and close the copy windows the bottom area just turns green and the window does not close. If i hit the start bar nothing happens, it just goes green on the bottom and nothing responds. One time I was able to hit the start bar and open another explorer windows while the progress bar was still up but soon as it was done lock up. no response from the screen. Otherwise the unit is working great, but its unmodified and that needs to change.
Posted Mar 30, 2009 · 06:52 UTC#2
have you calabrated your screen
Posted Mar 31, 2009 · 05:14 UTC#3
This worked.
I guess since it felt fine moving around the other windows I did not think I would need to do this step. Thanks for the quick reply.
